Ok, im about to buy a 96-98 B20b and I know I have to do a couple of changes in order for it to go into my OBD1 harness. I need a list of things I have to change from it. I know I have to change the starter and alternator..what else..
research it out like everyone else. My one thing I can bring to mind tho is depending on the engine the oil pump will either be OBD1 or OBD2. If it's a JDM engine it's OBD1. I'm saying this since the oil pump will either have a spot to mount the crank position sensor or not. If you're car is a OBD2 you might need to change out the oil pump to a OBD2...and LS or GSR one will work...or a Type-R if you want crazy pressure. Makre sur eit's 96+ tho
