B b20_silver Junior Member May 11, 2003 #1 Can I use the rev limit off the LS Ecu? Or is it not safe to tach it out that high since the redline is at 6300 for a b20b?
E_SolSi Member of the 20 nut club Moderator VIP May 11, 2003 #2 your peak power is at 5400 right now (if its a stock B20B) just shift earlier you dont HAVE to wind it out to the rev limit every time
E_SolSi Member of the 20 nut club Moderator VIP May 14, 2003 #4 well its a habit that is making you slower you want to shift a few hundred RPM past your peak power the longer you wait the more your power drops id shift at 5800-6K at the highest
