B20B swap in auto 98 EK
Discussion in 'Engine Building' started by jdmdad204, Oct 2, 2006.
  1. jdmdad204
    jdmdad204 New Member
    I justed wanted to know wut mounts would work im basically putting a B20b in my hatch is the only thing is im converting it to manual and i wanted to know if the stock ek b16 mounts would work even if the chasis is for auto. Should i get aftermarket mounts or should i just use the stock b16 mounts
  2. GSR99si
    GSR99si Junior Member
    All stock mounts will work except for tranny mount you will need to get it from 99-00 si
