B20b Turbo
Discussion in 'Engine Building' started by MACspeed, Feb 25, 2003.
  1. MACspeed
    MACspeed Junior Member
    Central Jersey
    Alright, I've decided to finally build a monstrous turbo civic. I'm about to pick up an 89 CR-X and I want to drop a B20 turbo into it. Don't need details about suspension or any of that crap. This is my first turbo engint that i have built and im not fully knowledgable about them. This is my plan so far:
    -b20 block, darton sleeves, micropolished crank, forged rods and pistons (8.5:1 compression), dry sump oil system
    -b20 head, port\polish, Type-R intake manifold port\polish, titanim retainers\valves, GS-R springs, oversize throttle body
    Things I need to know:
    -Is this a good plan to start with?
    - What size turbo (intercooled of course) can i run to use all of that low compression without taking forever to spool up? Would a supercharger work better?
    -What type of cams should I use (brand?), Who makes a good computer for turbo b-series engines? I dont really want to go hondata, im not really a great tuner yet
    -Who makes a good downpipe for this application? waste-gate and blowoff valve? exhaust system (i figure 3-in)?
    -Who makes a good dry sump oil system for the b-series (moroso?)
    :worthy: BOOST!
  2. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    Why use the B20 head? Get something that flows better and supports VTEC. Check out B20VTEC.com theres a good turbo project happening there.
