B20b vs. B18A
Discussion in 'General Tech and Maintenance' started by khai_tuan_nguyen, Jun 14, 2004.
  1. khai_tuan_nguyen
    khai_tuan_nguyen Senior Member
    I was wondering if the the B20b has thinner cylinder walls then the LS blocks (stock)?
    I know the bore size is different, but if I bored the Ls to 84mm like the CRV would the walls be the same or would the B20b walls be thicker?
    Thanks
    Khai
  2. phunky.buddha
    Dallas / Fort Worth, TX
    LS stock sleeve @ 84mm would be thinner than the stock B20 block.
