b20b with b16a crank
Discussion in 'Engine Building' started by integramic, Aug 27, 2003.
  1. integramic
    integramic Member
    Can you tell me if there is anything differentt I need to do (other then have custom rods or pistons) to use a b16a crank in my b20b? Let me know. Thanks. Is there a difference in the timing?
    I see you guy have seen this before...Although not very helpful. The process has alrewady start and hoping to be at Nopi. Here is the information I have.
    B20b block (98)
    type r head (01)
    ls crower rods
    custom ross pistons with heat coating and wrist pin moved 3mm
    All valve train redone with oversized on exhaust
    I wiil be running a turbo with a t3/t4 fornow
    b16a2 crank (99)
    ctr cams
    If any other infromation for the timing is need let me know. I have all the basics I think. btm, cam gears, hondata,
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Why??
  3. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    here we go another RS ratio thingy....don't bother man
    Milan
  4. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    b20 crank is good enough.
  5. lsvtec
    That is what I was figuring too, I was hoping to get to go off about it again. I haven't had one of these in a while. :D
  6. E_SolSi
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    do it
    :D
  7. B16
    B16 Super Moderator VIP
    yay area, CA
    if you're running boost, you're better off using stock cams than ctr (too much overlap) unless you kill the overlap with gears.
