B20B/Z questions
Discussion in 'Engine Building' started by sihatchback_RL, Jul 12, 2004.
  1. sihatchback_RL
    sihatchback_RL Senior Member
    i heard that the JDM B20B came with 10.2 compression and came with 33mm valves. True? or is it just like the USDM?
  2. brian11to1
    brian11to1 Senior Member
    Hmmm what did the US spec ones come with?
  3. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    I believe that the b20z had a higher CR than the b20b, couldn't exactly remember what the differences were. Give me a second to find out.
  4. JDMilan
    Boca Raton, FL
    B20B B20Z
    Available 97-98 99-00
    HP 126 @ 5400 146 @ 6200
    Torque (ft-lbs) 133 @ 4300 133 @ 4500
    Ecu redline 6200 6700
    compression ratio 8.8 9.6
    Cams in/ex 9.70mm (+.3mm) 10.03mm
    Valves 31mm intake, 28mm ex 31mm intake, 28mm ex Cyl Bore 84mm 84mm
    Stroke 89.0mm 89.0mm
    hmm........there you g00
  5. sihatchback_RL
    from many observations, many people told me that JDM b20 only came in the B20B version, but with 33mm valves, 84 bore, and a compression of 10.2. Which as the USDM B20B is totally different from the JDM one with smaller valves and 8 compression. So is the JDM B20B is the equivalent to a USDM B20Z? C'MON all you frank motor guys, HELP!
