B20b
biglee414
i was just wondering what car this engine was from? what some specs on it are? what else it would take to put it in a 90 hf? and a ballpark cost for all of this. any help would be very much appreciated.
B20B
Displacement (cc): 1973
Power (bhp@rpm): 126@5400
Torque (ft/lbs@rpm): 133@4300
Compression Ratio: 8.8:1
Bore (mm): 84
Stroke (mm): 89
Cam Design: dohc
VTEC?: no
OBD: 2
Year(s) Produced: 1997-1998
In the following car(s): Honda CRV
I don't even know if the intake manifold is going to be able to get crammed in a CRX.
is this going to be worth the time and money i will have to spend? i know i should probably go vtec if i get it, but again, money!
the one i am looking at has everything included, i would just have to swap it in. oh yeah, it already has obd-0 conversion(dizzy, ecu, im). how hard will it be for someone who has never swapped before?
Originally posted by machine@May 28 2003, 03:37 PM
its not hard but the sleeves are kinda weak no major boost
Uh... no. You can boost a B20B/Z just as much as a B18B.
