b20z crank position swap sensor problems
Discussion in 'HYBRID -> EG-EK / DC' started by deity, Jun 15, 2005.
  1. deity
    deity Junior Member
    ok, im using my obd2 `1996 d16y8 wiring harness to wire up my 2001 b20z2. the crank position sensor on the y8 is 3 pin. but on the b20 its two pin.
    this is really throwing me for a loop. can someone shed some light on this please?
    thank you
  2. smooth_criminal
    smooth_criminal Senior Member
    color mathc the two wires and leave the last one disconected.
  3. deity
    deity Junior Member
    are you sure about this?
    im using a 1996 od2 ls ecu
  4. smooth_criminal
    yes, i had to do the same thing in my car. i went from a 3 prong LX motor to a 2 prong LS setup.
  5. deity
    deity Junior Member
    worked like a dream. thanks man.
    i lit her up for the first time tonight. NOTHING soundsl like a 2 liter :worthy:
