Here goes.
I am going to install a B20Z2 with a cable transmission (90 integra), into a 1995 eg. The eg is an auto so I will be replacing the transmission mount Bracket. So far I have ordered the following.
1995 teg rear transmission bracket.
1995 engine mount bracket. ( timming belt side)
1995 civic dx manual transmission mount bracket, which will be welded into place.
basically, it will be like installing the B18B with cable tranny into the eg correct?
Now, I am not sure what mounts I need to use. I was looking into the hasport mounts but i am not sure which kit to buy. I do not want to order the wrong kit.
Is the kit for the B18A the same as the kit for the B18B?
