B20z/vtec in a 1991 CRX
Discussion in 'HYBRID -> ED-EF / DA' started by Nyquil, Jan 11, 2007.
  1. Nyquil
    Nyquil New Member
    Considering buying a 91 CRX to drop this engine into. The crx has a D series motor how much of a pain in the ass is this going to be to swap in? what other parts will I need. Do I need a new tranny? Am I better off just dropping it into a 94 integra RS, if so what tranny should I use for that? Crx is much cheaper and lighter so I am leaning towards it I geuss I need some advice.
  2. 97hatch
    97hatch ?
    Anderson IN
    you will need lots o parts
  3. 801CRX
    801CRX Got Rice?
    UTAH
    Correct CRX is better for the power to weight ratio. But some say they have probs with torque steer.
    But anyways the parts your going to need for the CRX are:
    B20Z or B20B block
    B16 or B18 VTEC head
    1995-2001 GSR(integra) water pump and oil pump
    Since its OBD0 use the PR3 ECU
    Head bolts for head you choose
    Intake manifold for the head you choose
  4. Nyquil
    Nyquil New Member
    I have the entire longblock pre-assembled. im wondering what I need to get it into the car.
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    and go with the ecu thats for the head also,and dont for get mounts and linkage,and a b series tranny
  6. 801CRX
    801CRX Got Rice?
    UTAH
    Ohhhh................
    For the CRX:
    Any B-series cable tranny or cable to hydro conversion.
    Mounts, Shift linkage and the PR3 ECU or piggyback it.
    Your going to have to pound a dent into the drivers side frame by the altenator to clear the B20 altenator pulley.
    You can find all the parts i lsted at hassport.com.
    Good luck with it!!!
  7. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    He's exactly right on everything, but I just wanted to point out that you have to do this to any B series into CRX, not just specifically the B20.
    Just so theres no confusion.....
    -Andrew
  8. CRXSi86
    CRXSi86 Fatty
    Brunswick, OH
    the ecu will def have to be chipped too... if you are using the pr3 it wont be able to dunp enouigh fuel for the 2.0 displacement... im doin the same thing in my 86 crx, im gettin all my wire shit done at rywire.com i suggest you check it out. as for the tranny, im using the YS1 LSD. hard to find but well worth it so you have some traction...
  9. CRX Si-R
    CRX Si-R eat my shwartz
    Northern Virginia
    Yea I'm thinking about doing the same swap. But I don't have CRV 2L experience. With a B20Z/B and B16A head, how much whp/tq can you put down. I have the stock DX dual point in my CRX and am debating on doing the crvtec, flatout b20z nonvtec turbo, or an ITR.
    I read up on a B20B (126hp/130tq)
    and a B20Z (146hp/133tq? I think)
    What years did the z/b come from different sites say different things
  10. CRXSi86
    CRXSi86 Fatty
    Brunswick, OH
    the b20b came from the 97 and 98 model CR-V and the Z is from 99, 00, and 01 CR-V's 02 and up is the K24, completely different block. I believe or from what i have heard the B20 VTEC will put down 180-190 to the wheels, TUNED maybe more or less but around that area...
  11. skrotm
    skrotm if you boost it..........
    moultrie, ga
    my hybrid put down 222whp using a chipped p28 and chrome tuning.. i had a b20z bottom end. stock bore. ported b16 head milled 35 thousandths. eagle rods. 12.1 cp pistons. stock head gasket. crower 403 cams. edelbrock manifold. bbk 70 mm throttlebody. and a comptech header......... to much money for only 222 hp. it was a beast though. i had to run a race gas blend all the time cause i didnt want to pull timing from the motor.
  12. Andrew
    Tallahassee, FL
    Tell me about it. Built D-series = $ > hp
    Next time(if I stay 4cyl) I'm going homemade turbo. BEST bang for the buck.
    Or I'll just buy a 'stang and be done with it.
  13. 801CRX
    801CRX Got Rice?
    UTAH
    Yeah cheap racing is the best way to go unless your loaded.
