Take them to the shop. Accelerated wear from camber is usually a sign of bad toe alignment; the toe can be adjusted(it's at the front of the trailing arms).
the cheapest way is like magana559 said. washers and longer bolts... just makes the alignment process take longer because of setup and camber sweep, each and every time...
