Bad Fuel Pump?
Discussion in 'General Tech and Maintenance' started by VTECPOWER, Oct 11, 2005.
  1. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    So, i think my fuel pump is fried, changed main relay, all fuses are good, dont hear the "whine" when the key is on the on position. I think it may have gotten fried when i was extending the wires for my map sensor to use a map sensor mounted on the throttle body on my skunk2, i was re-wiring it when i lost a wire and it touched the positive terminal of the battery, causing a spark.
    Is there any other ideas of things to check first?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Take out your pump, dump it in a bucket of oil, wire it up and turn it on..
  3. VTECPOWER
    Winchester, VA
    Is there any way to test it electrically?
  4. reikoshea
    Dallas, TX
    12v dc and ground?
  5. VTECPOWER
    Winchester, VA
    My dad checked some things online thismorning and we will check out a few things electrically before going and replacing this bastard.
  6. formby
    formby learning in progress
    look for the possitive wire on the pump harness and just tap it and run 12v to it.... it should turn on with out a ground...its grounded on the pump housing in the tank...
  7. VTECPOWER
    Winchester, VA
    With mine, someone did something, and it's grounded to the chassis, theres a wire nut near the housing in the interior, and a wire runs to a bolt for a ground.
  8. formby
    okay just tap into the positive wire on the harness....and it should turn on if not....do the oil thing...never heard of it but try it
  9. VTECPOWER
    Winchester, VA
    So just run the positive wire on the fuel pump to a 12v source. Thanks.
  10. formby
  11. spoonfedcrx
    spoonfedcrx Junior Member
    this might be a stupid question but if u touched the positive terminal and seen a spark and now ur pump doesnt run did u check the main battery fuse to see if its blown. if u already have disregard and listen to those guys
  12. VTECPOWER
    Winchester, VA
    Ive checked all the fuses, my ecu is fried, ordered a new one, because the led light stays on, and you can see where the solders are broken.
  13. reikoshea
    Dallas, TX
    ouch...sounds painful.
  14. VTECPOWER
    Winchester, VA
    Yup, $140 painful, pr3 should b in today.
  15. VTECPOWER
    Winchester, VA
    Got the pr3 today, fixed an exhaust leak, :thumbsup: all good now!
