daGSRhatchNEPA
I love my Honda
The car is fine until i take it on the highway and then the car when i hit the Brake Pedal and the Temp Gauge Hits High and then the car starts bucking. There is a little Box with a Brown Plug in it Just below the Fuse Panel that Keeps Clicking as this is Happening. I am Clueless @ this Stage.
I bought the Shell an 93 Ex & swapped a SIR II JDM B16a PR3-2 motor in it.
> Reading other forums i found that its either because i Wired the Negative on the Battery to the Trans/Motor OR
> The Fuel Sending unit wire is shorting & to Trace the wire all the way to the Gauge Cluster to the Fuel Sending unit.
?? Any Pointers on where i can start before i just Re-Wire the Entire Car??
