bad mornig so far!!!! oil everywhere!!!!
Discussion in 'Engine Building' started by DESPAIN, Dec 4, 2009.
  1. DESPAIN
    flower mound TX
    ok, so i ahave not driven my car in a few weeks. so say what the hell i will take it to work. for those who dont know i have a 92 prelude with jdm h22a, fully built lower end and stock rebuilt head. less than 25k miles on it. i am pushing about 425hp. so i let it warm up and stop about 3 miles from my house to get some gas. i leave it running and run in the store and pay for the gas. well on my way out to my car i see oil pouring from under my car. so i run over a turn the car off. pop the hood and from what i can see its coming from either my head or under the plastic cover for my crank pully side of the engine. no cel no oil lite on car sounds fine no knocks or anything like that. but oil just pours out when i have it running. doesnt seem to be loosing compression or anything. any have any ideas what it could be or what to check for. i have not had a chance to have a ggod look yet as i was on my way to work. i took it back to my house and parked it till i get off work.
    thanks in advance guys.
  2. TurboMirage
    425HP from an NA build? huh?
    maybe you have too much oil pressure? pull that front cover off and see if one of your front seals have moved, or your oil pump may have started to fail.
  3. DESPAIN
    flower mound TX
    not n/a i am turbo'd. pushing about 18psi. yeah this is what i was tninking. but the oil pump was new. and like i said whole engine was rebuilt with new parts. i was not even hitting any boost. i never do till it warms up all the way. just drove it really easy to the gas station and was putting gas in.
  4. DESPAIN
    flower mound TX
    Bump!!!!! Please help!
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well really the only thing you can do is clean it up, and start the car and try and see if you can spot where its coming from.
  6. 99sidude
    Ohio
    I've seen it where the crank seal on the timing cover side totally goes out and it dumps oil everywhere.
  7. d-mon
    d-mon what r u compensating 4?
    18psi + poor crankcase ventilation could push seals out.
  8. DESPAIN
    flower mound TX
    the thing is i wasnt hitting boost. i was busy all weekend and didnt get a chance to look at it. maybe today when i get off work!~
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    probably pushed the seal on the end of the cam out..where the camgears are..
  10. DESPAIN
    flower mound TX
    yeah its either that or the oil pump. from what i can see. i have not thrown a cel or anything so i dont think anything is messed up. i have blox cam seals in you would think they would hold up!
  11. EGZISKO
    EGZISKO New Member
    Y TOWN ARIZONA
    Well good thing ur not using tha car lol and check that seal i could be that
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    no the blox cam seal goes in the dizzy side of the motor..on the other end where the cam gear goes is another cam seal..its like a big o-ring with some kind of spring in it..the cam goes inside of it,which inturn goes inside of the camcap,if there was too much pressure it probably pushed the oring out of place..its a real easy fix
  13. DESPAIN
    flower mound TX
    will i have to take off my head? or just the valve cover?
  14. Matts96HB
    Matts96HB . Moderator VIP
  15. Fernpatch
    Fernpatch Member
    Bellingham,WA
    Pull the valve cover and the timing cover and take a look around. I have seen many cars push the front crank or cam seal out of place. I have also seen a few f series engine spit the balance shaft seal out and puke oil everywhere. I don't know off hand if the h22a has a set of balance shafts but that would be another good place to look.
  16. TurboMirage
    pretty sure the h22 does.
  17. Matts96HB
    Yeah it does, I think it's Kaizenspeed that sells a balance shaft eliminator kit for it..
  18. pooksy64
    pooksy64 RidetilldeathdousparT
    HOUSTON tX
    +1, might have blown a seal, doesnt mean you had to be @ WOT. but oil psi + hi crankcase psr, low ventilation. But I would agree, clean up the mess/jack the car up/run the engine/ lay under an watch.:eek:
  19. DESPAIN
    flower mound TX
    it spews so bad i dont think i would want to be under the car.........:ph34r:
  20. 78civic
    78civic Junior Member
    NW MS, Y'all
    Going out on a limb.. Blown oil sending unit? Split oil filter? I guess it would smoke if so..
    I didn't see if it's on one side or the other? front or back? (as it sits in the bay)
    Hey, did you re-install the oil restricter in the top of the block?
    You might be flooding the VC..?
    Just my .02
    E
