Ball Joint
Discussion in 'Civic and del Sol - EG and EK' started by porkfried83, Feb 28, 2012.
  1. porkfried83
    porkfried83 New Member
    ME
    I was wondering if there was a way to remove a ball joint from a 95 Honda Civic. Without bringing it to a shop or renting the tool. Anybody have any ideas?
  2. ls94civic
    ls94civic New Member
    vermont
    good luck without the right tools
  3. potatoe
    potatoe New Member
    smack it with a heavy hammer on the knuckle that the ball joint is in. sometimes you will get lucky. search youtube. there is a few good videos there. be carefull. you might get some help from auto zone or advanced auto with free tool rental also
  4. reikoshea
    Dallas, TX
    Thats a helluva job. It's one of those that is very long and very painful without the right tools. If you try some home brew methods you can end up damaging your steering knuckle or the fitting for the ball joint (making it very difficult to put in your new one).
  5. porkfried83
    ME
    I forgot to mention its not on the car. I took the whole front suspension off, to replace all the bushings.
  6. porkfried83
    ME
    I rented the tool for $105. I get the $100 back when I bring it back.
  7. porkfried83
    ME
    Hopefully it works, I know how working on cars go. Think its gonna be a easy job and then turns out to be a bitch!
  8. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    If the knuckle is off.....I bet a small auto repair shop will put it on their press for cheap.
    If you can find a socket that fits over the stud and seats on the metal of the ball joint...you can hit the socket with a hammer.
    I am getting new lower ball joints installed tomorrow....but the shop is doing it for me....with an alignment.
  9. porkfried83
    ME
    The tool didn't work! The attachments didn't fit the knuckle. I got one off and new one on with it only cause I rigged it on there. So I stuck the other one in the side of the vice, and got it free a lil bit. Then pounded the hell out of it with a mallet. I could have used the vice this whole time. Oh well now I know how to replace a ball joint.
  10. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    This is the way to go. Part is already removed, take it to an automotive machine shop and have them do it. The one's on my '91 hatch are pressed in and held secure with a clip.
    I have a 10 ton press, did a full polyurethane bushing job and when it came to replacing the front ball joints, I let the pros at a nearby automotive machine shop do that work. Wasn't expensive and was well worth the cost.
  11. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    I always take the spindle off, brace it upside down, and give the balljoint stud a few solid hits with a 4lb hammer. They always pop right out..
