http://www.bandwidthplace.com
test your bandwidth and post your results...
i've got cable in NY
730 kilobits per second
Communications - 730 kilobits per second
Storage - 89.1 kilobytes per second
1MB file download - 11.5 seconds
Subjective rating - Good
anyone ever heard of or read about windows XP and 2K using 20% of your bandwidth? is this true?
Windows uses 20% of your bandwidth !
Microsoft reserve 20% of your available bandwidth for their own purposes (suspect for updates and interrogating your machine etc..)
Here's how to get it back:
Click Start-->Run-->type "gpedit.msc" without the "
This opens the group policy editor. Then go to:
Local Computer Policy-->Computer Configuration-->Administrative Templates-->Network-->QOS Packet Scheduler-->Limit Reservable Bandwidth
Double click on Limit Reservable bandwidth. It will say it is not configured, but the truth is under the 'Explain' tab :
"By default, the Packet Scheduler limits the system to 20 percent of the bandwidth of a connection, but you can use this setting to override the default."
So the trick is to ENABLE reservable bandwidth, then set it to ZERO. This will allow the system to reserve nothing, rather than the default 20%.
Works on XP Pro and 2000.
