Base Map... Ls/vtec
Discussion in 'ECU's, Electronics, and Tuning' started by pills_PMD, Apr 25, 2003.
  1. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    b18a block/.25mm over pr3 pistons/ b16 head w/ ctr and itr everything...
    should i start with a base p72 map and tune from there??
    should i just go from the b16 map that i've made??
    i dont know if i trust the ignition advance from the b16 maps to run the ls/vtec...
    i know eric is using a p72... what should i start with!>?
  2. pills_PMD
    New Albany, OH
    ok.. simplified...
    what is a good ecu to run an ls/vtec ??
    gsr ecu? or b16? ITR? take your pick!! i just need a fucking base map! i'm more worried about ignition timing
  3. tnsxsear
    tnsxsear Senior Member
    gsr p72,all the way
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    I have had good luck with the P72. No problems with detonation. 11.5:1 compression and 91 is the best gas I can get here.
  5. pills_PMD
    New Albany, OH
    perfect, i'll start with a p72 map, and tune from there w/ the help of the wideband and hondata.
    thanks all
  6. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    You mean you weren't going to tune with VAFC and an autometer air fuel guage?
  7. pills_PMD
    New Albany, OH
    it's funny because i have a vafc and an autometer a/f gauge too
