Basemap Questions???
Discussion in 'Forced Induction' started by reckedracing, Jul 27, 2006.
  1. reckedracing
    reckedracing TTIWWOP VIP
    NY
    So i had chris send me the bin's of the 2 basemap chips he sent me...
    neither bin has "retard timing x degrees per pound of boost" checked off...
    do most tuners adjust the timing manually?
    i'm just trying to figure out if this was an error or not...
    i guess i should compare it to a stock P28 bin huh?
    also, one of the bins has stock injectors of 240 and new iinjectors of 343...
    not sure if i'm missing something on this one too, or if it was a mistake...
  2. reckedracing
    NY
    so stock P28 redline ignition is 28.25
    basemap 0 psi ignition is 28.25
    11.2 psi ignition is 20.00
    so a total pull of 8.25 @ 11 psi
  3. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    If you goto the tools menu, then boost table adjustments, you can adjust in there.
    It seems like you have it set to .75/psi already.
    I would try that first, if the EGT's sky rocket quickly, bring it back to .5/psi
  4. reckedracing
    NY
    yea, i know where the place to adjust it is...
    i thought that the box would stay checked off...
    i guess it reverts back to "make no changes" everytime
    i'm a crome n00b
  5. reckedracing
    NY
    do you need plug-ins to record all these things? or does datalogging do it automatically?
