I've been seeing alot of posts on how to make a killswitch yada yada..
best way imo is to have a ignition killswitch, this makes it so your ignition wire is dead, if you do starter then you can push start your vehicle.
Parts needed
Toggle switch
Male/Female connectors
24 AWG wire Dont use the solid style.
Wire cutters/crimpers
Computer safe "Smart tester"
Nearly all honda ignition wires are Black with yellow stripe, This wire is located under your dash, in the ignition control wire bundle, the way to check it is the ignition wire is to get a smart tester that checks for ground, touch the tester to the wire, now run through your key steps, off, accessories, on, start, as soon as you get to the on position the light should light up, now go into start and it should stay lit up even when started. this is your ignition wire.
Now for instalation
Get your kill switch, figure out where you want to mount it.
Find your ignition wire, cut it, try to turn your car on to make sure its dead.
now put a female end on both wires.
Take your 24 awg wire, and find out how much you need to mount your switch, put 2 male connectors on one end, and 2 females on other.
connect your switch
Mount it - dont mount your switch somewhere noticeable, some good spots are, in your penny tray to left of your steering wheel, under your dash, many other places just be creative, some people like to put it in back seat, me personally I want to be less noticeable as possible.
Test it
Love it
Clean up.
All of this costs about 5-10 dollars, and is great anti theft.
This should be done within 10-15 minutes.
I will be adding pictures probably this weekend.
Parts needed
Toggle switch
Now for instalation
connect your switch
Test it
Love it
Clean up.
