Basic Oil Change??
Discussion in 'General Tech and Maintenance' started by b18jdm, Jan 22, 2005.
  1. b18jdm
    b18jdm Junior Member
    well my friend is getting hes integra type r motor install tomorrow, what type of oil should he use?? also put some 10w30 or the 5w20??i know its not a smart question but is something we dont know, thanx for the help
  2. qtmac_mien
    qtmac_mien Senior Member
    most ppl i noe go wit 5w30..also kinda depends on where you live if it snows alot or if its sunny and hot.. but i would just go wit 5w30
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    since it is a swap, it's most likely a used motor, so i'd go with 10w-30...brand wise i use Exxon...it's cheaper than castrol and is the exact same as mobil 1(non-synthetic)
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Moving to appropriate forum.
    10w30 is good for just about any application.
  5. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    5w30 in the winter 10w30 in the summer.
