K2e2vin
i was searching for info on "split charging"(what the brits call it im guessing since ive only seen that term on uk sites) aka battery isolation. well i was trying to debate between a diode type and a relay type and came across this page: http://www.antares.co.uk/split_charging.htm
at the end, if you dont want to read it, it talks about a hybrid type switch but is vague about the design. it says its pretty much a relay type isolator but uses a differet trigger:
any ideas on how to make a standard relay isolator work like that?
The switch only operates when the alternator/charger can supply the loads without drawing on the primary battery.
