battery light problem
Discussion in 'Civic and del Sol - EG and EK' started by rkwoos12, Dec 28, 2008.
  1. rkwoos12
    rkwoos12 New Member
    Kentucky
    hey guys i finaly got rid of all my cels but i still have one last problem with my battery light i dont know how to fix this either i got a good battery and the Alternator if for a 92 accord and it charges good but its in my 94 honda civic ex would this cause the battery light?
  2. tabKola
    tabKola New Member
    Tewksbury MA
    It might, have you had the battery/alternator checked to make sure they are working correctly. Also are you sure you have everything plugged in like the sensor that controls the light.
  3. rkwoos12
    rkwoos12 New Member
    Kentucky
    yea every thing is pluged up right and battery and alt both work fine.
  4. serrilion
    serrilion In my own little world! VIP
    Vermont
    Sometimes the Light comes on when you - Terminal is lose, trigh tighting it, once happend to me, then it shut off.. :)
  5. rkwoos12
    rkwoos12 New Member
    Kentucky
    checked every thing the terminals are nice and tight. are civic alts differnt from accord alts?
  6. serrilion
    Vermont
    That could be, u could be over charging the Batt, :(, i dunno, but look up the specs between the Civic and Acord, im sure the acord has a bigger better alt then the civic :(
  7. rkwoos12
    rkwoos12 New Member
    Kentucky
    ok thats what i was thinking also, im probably gona go to a junk yard see if i cant trade for a civic alt thanks alot ill let you know what happens
  8. serrilion
    Vermont
    Ya I went to my freinds car today, The Acord stock depending on what year puts out alot more, but He has 1 in his civic, then again he Has a sound system that drains his bat and puts alot of stress on his alt, so he needed a bigger 1 :)
  9. 92egSi
    92egSi I need DOHC VTEC
    Did you check how much the alternator was charging?
  10. rkwoos12
    rkwoos12 New Member
    Kentucky
    yeah it was 14.7 something i for get but it was above 14
  11. serrilion
    Vermont
    Humm... bump for anyone who has a tester + a civic with a good alt to answer this mans Q's haha ;)
  12. rkwoos12
    rkwoos12 New Member
    Kentucky
    i belive my main problem is the accord alt. thanks every one for you help
  13. 99civicJDMh22
    99civicJDMh22 New Member
    Austin, Texas
    alternator is bad the light only comes on when alternator is not charging
  14. rkwoos12
    rkwoos12 New Member
    Kentucky
    it chrages fine tho nothing wrong and has a great one month old everstart battery
  15. serrilion
    Vermont
    Haha! Trust me its the acord alt... just take out and replace :)
  16. rkwoos12
    rkwoos12 New Member
    Kentucky
    will do, thanks alot every one for your help. :)
  17. 99civicJDMh22
    Austin, Texas
    i would just replace the NEVER START battery to you dont want that junk in your car
  18. rkwoos12
    rkwoos12 New Member
    Kentucky
    lol nah i didnt pay for the new battery so idc it starts my car fine ever time
  19. dixey21
    dixey21 Hells Hatchback
    96 and up Civics come with a 75 amp alternator while the accord equivalent come with an 80 amper. And the green plug on the back of it, is it pinned the same way as the Civic? But the difference in amperage would cause the ECU to believe that it's overcharging the battery, which it kinda is. I would swap it out and see, but beware of junk yard parts. it's asking for problems with that kind of part.
  20. rkwoos12
    rkwoos12 New Member
    Kentucky
    ok thank for your help.
