BB turbo oil requirements, pressure
Discussion in 'Forced Induction' started by rfrumusa01, Feb 27, 2008.
  1. rfrumusa01
    rfrumusa01 Bean Cakes
    Rochester, NY
    I have a ball-bearing GT28RS turbo.... On Garrett's website, they claim a ball bearing turbo should see no more than 40-45psi oil pressure (they apparently have small demand for oil). Past 4k RPM's, I see 70-75psi. I need a restrictor... anyone know where to find a restrictor for this turbo or some sort of universal one that will get me down to 40-45 psi max? Also, how much more over stock oil capacity should I be putting into the engine? I know you are supposed to have more to compensate for the turbo lines...
    thanks
  2. rfrumusa01
    Rochester, NY
    nobody??? seriously??
  3. get_nick
    Washington State
    i know a couple people running them on their sr20det's. not sure on the oil pressure coming out of the engine, but i haven't heard of them having any problems with the oil pressure.
  4. Sko0terMan
    Sko0terMan Member
    Los Angeles
  5. rfrumusa01
    Rochester, NY
    thats perfect. thank you. now what about the oil capacity? how much should I have over stock in the engine?
  6. Briansol
    with the correct line size, pressure won't be an issue.
    remember, the line is 3m from the pressure gauge and it drops significantly every inch it has to tavel.
    use a -3an feed, and you'll have no problems.
  7. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    Def use the restrictor. I was running a GT28R on my other car and it required it as well.
  8. silver
    silver Senior Member
    St. Louis
    Garrett recommends very low oil pressures for their BB CHRAs, so a restrictor at the minimum is required (preferably with an inline oil filter as well; 10 micron seems to work well).
