BBK Intake manifold news
cycloneb18c3
just to let everyone know, the AEM fuel rail and regualtor will NOT work on the BBK intake manifold for the GSR's. I just tried with my brothers, turning the regulator everywhich way, and you cannot bolt the rail on, with the regulator on it. So the only thing I can think of is running a universal FPR and connecting it to the fuel rail...
the stock fuel rail dosent even fit with the stock regulator..... I made it work, by using the stock GSR rail, and the aem regulator upside down. the adjustment screw/bolt is against the plenum of the manifold, but it works....
I think I may need to get something to space the FPR out a 1/2-3/4 of an inch...
who makes a rail that bolts to the firewall???
how does it connect to the injectors?
I know about the FPR's that bolt to the firewall, but never heard of a rail...
lol the rail is in the same position... but if you run a rail like the golden eagle rail, you can set it up to use a FPR liek the aeromotive...
heres a good write up:
http://www.honda-tech.com/zerothread?id=577983
