bbk throttle body on b16 crx problems...
Discussion in 'HYBRID -> ED-EF / DA' started by goldgreen90ef, Jun 12, 2007.
  1. goldgreen90ef
    goldgreen90ef goldgeen90ef
    cold ohio
    i just put a bbk throttle body on my b16, and now it idles above 2 grand, could the wrong tb gasket cause this? i tried to adjust it but the screw only goes in so far... thanks
  2. eg6sir
    have you checked the TPS..
  3. goldgreen90ef
    cold ohio
    no i havent checked the tps yet, would that just go by voltage or if ther is a problem would it throw a cel? thanks
  4. eg6sir
    it wouldnt necessarily throw a CEL.. also check the IACV..
  5. goldgreen90ef
    cold ohio
    should i try to adjust the tps when running or when the car is off? if i need to take a voltage mesurment what wires do i put it on? thanks
  6. goldgreen90ef
    cold ohio
    thanks guys...
    after all that it ended up being something with the blade...(not properly shutting)...
  7. eg6sir
    you mean the throttle plate isnt sealing.. is the throttle body used?? or did you buy it new?
  8. goldgreen90ef
    cold ohio
    i bought it used from a buddy, worked fine on his b18 turbo, thought it would be ok for my b16, o well back to stock...thanks
  9. eg6sir
    if it was fine on his car, then its most likely something else.. did you change the throttle body gasket when you put it on..
  10. goldgreen90ef
    cold ohio
    ya i did, three separate times, finally repairing the one that he had used, which did help the problem, but did not fix it. what ended up making me take it off is that i got to idle o.k., but when ide rev it up, it would get stuck between 1200-1500rpm, and i could go out to the throttle wheel and tap it, and would go back to normal.... pain in the ass....
