BBQ/Swap meet?
Discussion in 'NorthEast' started by ep3moschini, Dec 19, 2007.
  1. ep3moschini
    ep3moschini I R T3H NO00Bz!
    Northbridge Ma
    when is the next one? c'mon now! ;)
  2. ep3moschini
    Northbridge Ma
    I have all this stuff! and more!!!!
    1991 CRX rolling shell picked up (includes all suspention and brakes)
    P28 ecu chipped and socketed
    OBD0-OBD1 jumper harness (brand new)
    91' crx si body harness
    91' crx si engine harness convertred to accept obd1 dizzy and injectors
    91' crx si dash
    B&M short shifter
    91' crx si rear disk brake conversion (new remanufactured calipers)
    D16a6 Block
    2 D16z6 heads one assembled one appart ready for the machein shop
    d16z6 dizzy
    d16z6 intake manifold with all sensors working
    d16z6 t/b boared all sensors work
    d16z6 header
    p29 ZC standard high compression pistons
    d16a6 rods
    d16a6 crank
    d16a6 oil pan / pump / pick up
    d16a6 water pump
    DC2 Integra brake booster
    DC2 Integra brake master cylinder
    DC2 50/50 prop valve
    d16a6 freeshly resurfaced flywheel
    d16z6 tranny (needs rebuild)
    91' crx si radiator and hoses
    d16z6 fuel rail and injectors
  3. Briansol
    you didn't show up for the last 2 or 3....
    1 person likes this.
  4. Airjockie
    Airjockie Watanabe Whore!!!
    Meriden, CT, USA
    right now the house is getting work done to it, and once most of the crap is put back together...then I'll toss another meet up.
    But get ready for some huge one's in the spring....I got a lot of stuff to sell....
  5. Celerity
    Celerity Well-Known Member
    Yeah, this spring I'm DEFINATELY in. I NEED stuff, and I need to lighten my load big time.
  6. ep3moschini
    Northbridge Ma
    SHHHH! I had a weding to attend last time!
