BC Racing suspension
Discussion in 'Vendor Classifieds' started by Cape Customs, Jan 1, 2011.
  1. Cape Customs
    Cape Customs New Member
    FL
    Full line of bc racing suspension for civics, integras, s2k, rsx, preludes and just about any other car you can think of. here is a little info about the products.
    BC Racing Coil-Over Damper Kits offer 32 Levels of damping force adjustment, full-height adjustment, and are matched with front and rear Pillow Ball upper mounts for camber correction. Springs are made of SAE-9254 Steel, and are tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating spring durability was highly improved. You will own full control of your vehicle regardless if you are driving on a normal street, up to a mountain region, country road or formal racetrack.
    Features: - Spring Rates: 12kg Front and 12kg Rear - 32 Levels of Adjustable Damper - Pillow Ball Upper Mounts front and rear! - Mono tube design for maximum performance! - Adjustable Ride Height - Aggressive Spring Rates - Single-Cylinder Design - Exclusive design for each vehicle! -
    All coilover damper kits come with 1 year manufacture-defect warranty. - All Hardware is Included Why you don't need to be skeptical about these coilovers...
    Interesting facts- Who is BC Racing? BC stands for Bor Chuan Who else does BC make? BC racing makes coilovers for many brands that you have most likely already considered :) and now they are selling their own brand in the USA
    1 person likes this.
