Bearing size for aftermarket rods
cheese9988
VIP
I am looking to use stock bearings with an aftermarket rod for a d series motor. I know the bearings will work fine on the crank. If the oil squirters line up, the gap is checked 180 degrees around each bearing and meet stock specifications using the recommended grease, should I have no problem using that bearing? I can no longer contact the person who sold me the rod, so I cannot ask him this question.
take it to a machine shop. if the rods are forged you might have to notch the block and get some acl bearings sized for them. never reuse them
That was fast :) Yes the block does need to be notched. Whats involved with sizing a bearing, can they size any bearing?
dude
just take it to a reputable place and ask them if you can watch them.
