typesiracing
I know how to choose what color the bearing is supposed to be. This is my setup...b18c1 block with b18b rods/crank connected to b18c5 pistons(gsr block, type r pistons, ls crank/rods) with b16 head -crower dual springs/retainers and sir cams . I have a hookup at the local honda dealership so i'm wondering if a yellow bearing for a acura b-series is the same spec as a yellow bearing honda b-series.
1.So can i order my b18 bearings from honda?
2.If so what do i get ls or gsr main bearings?
3. What year make and model should i tell honda?
(probably 94 del sol vtec)
