belt for unorthodox crank pulley
twerker08
Member
I was wondering if I can use my stock belt with this pulley (unorthodox) or if anyone knows the size I need.the motor is a B18b1.And there is notches on both sides of the pulley,on the top rails does anybody know what they are for?Thanks for the help.
do yourself a favor, sell the UR pulley, well if it's a crank pulley. the oem unit ownzzJOoo.
Milan
agreed
underdrive pulleys do more harm than good
the 2-4 hp it MIGHT gve you is not worth the fact that it unbalances your engine causing added wear and premature failure... or the 2 alternators every month that youll be burning up
