belt issues
brownkobe8
right now im driving around my dad's p/u oooollllldddddd truck.
Now i when i got the h22a for pretty cheap, now i was reading threads that im able to keep all my accesscories(power steering pump, alternator w/ bracket as well a/c bracket).
Now like for the a/c and alt, in threads i was reading to use the accords bracket for both. I did and bolt it up, now for the power steering i just used a bracket from a 98 h22 and it worked w/o modifying the hose.
So far everything bolted up, now i dont know what type of belts do i use?
Like i do i get the these belts from the 93 prelude or from the 96 accord?idk if their custom length, also if anybody done this if you remember what were the size?
Yea 93 h22, in a 96 lx. We have already taken care of the accord engine harness. I have gotten my ecu jumper from rywire as well, my vtec sensors as well.
Right now just waiting, like right now I need help for the belts. I have accord p/s pump, accord alt and a/c compressor. The p/s works great cuz I'm using bracket from 98 lude cuz it seemed I didn't need to mod the p/s hose. It seemed a great idea cuz couldn't find those hose specialist.
Like do I still use accord belts, lude's t-belt?
Or all prelude belts?
Or are they special lenght?
IF I remember right my ps was a special size belt, we just measured and bought the appropriate one. The ac and alternator belt was the stock accord one.
My h22 came with a crank pulley that was different than the f22 so I used the ps, alt, and a/c off the h22 (mounts too). If you do the manual belt tensioner mod, I found that ordering a belt 1 tooth over the normal h22 size is perfect. 157 teeth I think. Since I used the h22 ps pump, I just bought the OEM size ps belt.
Bob
