bent lower control arm
redef91
would a bent lower control arm make my car pull to that side it was bent on. :confused: :confused: :confused: :confused:
Anything that is bent in your suspension is going to cause undesirable effects. I would replace anything that was damaged and consider getting an alignment also.
Why don't you get under your car and look? I bent my driver side LAC at an AutoX event and its noticable if you sight along the spine of the LCA when you're under the car whith the tire off.
the bushing were totaly gone on both sides
