Bent object on the bottom of the head
Discussion in 'Engine Building' started by mack1753, Jun 4, 2008.
  1. mack1753
    mack1753 New Member
    I picked up this 99' GSR head off this guy for a good price. After i got it though the first thing i realised is that there was what appeared to be a dowel pin that was all bent to **** sticking out of the bottom of the head. What exactly is the "dowel" sticking out of the head, ive never seen it on other heads before and how do i fix it?
    Thanks for the help guys, i really appreciate it :)
  2. stock98EKcoupe
    stock98EKcoupe New Member
    yep dat dem piece raught thur is a dowel pin. It just keeps the head from twisting around on you. You will want to replace that, you can get the at a honda dealership
  3. mack1753
    mack1753 New Member
    So i can just give it a good ole yank and it will pop out? I was going to order new dowel pins for the LS/VTEC conversion anyways...
  4. stock98EKcoupe
    yeah it should pop out, they arent' attached. If you have an extra tranny lyin around,they're in there too. I bent one and I just took one out of the tranny.
  5. mack1753
    mack1753 New Member
    Oh sweet! Thats nice to know, i got an old POS YS1 justing taking up space in the corner of my garage, ill see if i can pop it out of there.
    Thanks guys
  6. stock98EKcoupe
  7. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Dowel pin for proper head alignment.
  8. 93AccordEX
    93AccordEX New Member
    Just twist and jerk at the same time.... :D
  9. teggyguy
    teggyguy high density foot.
    Colorado
    words to live by
