Best 4 cylinder engine 2.0L or under N/A
Discussion in 'Members' Lounge' started by mpristave, May 6, 2011.
  1. mpristave
    mpristave New Member
    What is, in your opinion, the best 4cylinder engine ever 2.0L or under? Non-turbo no supercharger, just N/A motor. By best i mean whatever you think, longest lasting, best performance, most rewarding to build, most innovative, whatever you think "best" should mean.
    For me the best would be also in my favorite daily driver i've ever owned which was a Civic CRX with a D16. Amazing gas milage, lasted forever (almost 300k miles) until the car was destroyed by some idiot in a SUV rear ending me.
  2. eg6sir
    best motor under 2.0 would be the b18cR
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    k20a, or k20z1. it dont get better
  4. 99sidude
    Ohio
    I'd say the k20z1 from the 06-11 si. More potential and newer technology than a b series.
    edit: beat me to it! If you want to stick to a STOCK b series, I'd say the b18c (gsr) coupled with an lsd trans is the best all around swap. The lower static compression means the cylinders see less stress - aka longer lasting. The gsr trans is IMO the best geared for daily use.
  5. AHHVTEC
    Alabama
    the si has the z3 or z2 if i remember correct, the z1 is rsx
  6. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    Too bad they all like using oil.
  7. eg6sir
    i thought it said under 2.0L .. in that case.. K20xx
  8. jeffie7
    Maryland
    Not sure what its called but I'd vote the motor found in the BMW 1000RR
    makes 200hp and comes in at a whopping 1.0L
  9. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    K-series make power but they're not the best designed from an aftermarket/reliability standpoint(a lot of aftermarket parts to fix this); I believe the F-series would be a better choice(F20C).
    K-series for best performance, B-series as far as reliability/longest lasting
    Innovative goes to bike engines
  10. K2e2vin
    Raleigh, NC
    I've heard those make power but didn't know it was close to 200hp!
  11. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
  12. B16
    B16 Super Moderator VIP
    yay area, CA
  13. 99sidude
    Ohio
    The gsr I had is the only Honda motor I've had that didn't use oil. Didn't burn a drop even when boosted. Newer stuff is solid though.
  14. Briansol
    probably an f1 car :)
  15. jeffie7
    Maryland
    We have a 2007 Si. It has always used oil. A b series motor that doesn't use oil sounds like a messed up b series lol
  16. jeffie7
    Maryland
    I thought most f1 cars were in the 3.0 range plus were v8 v10 and v12
  17. Briansol
    2013, rules change. i'm sure there's some sample builds running already
    Formula One engines - Wikipedia, the free encyclopedia
    2013
    The FIA has announced the intention to the change the 2.4-litre V8 engines to 1.6 litre 4 cylinder engines[12] rev limited to 12,000rpm and other energy recovery systems in order to make Formula One more environmentally aware and to attract more commercial partners for 2013.[
  18. 92stoccord
    Salem, Ohio
    You know, the 1.8 in my E30 was a pretty bad ass motor.
  19. Briansol
    i sincerly hope you're joking
    (and yes, I also owned a 1.8 in my 318ti)
  20. 92stoccord
    Salem, Ohio
    Never had any trouble with mine :shrug:
