best b20/vtec header?????
Discussion in 'Engine Building' started by jspeccrx91, Jan 12, 2009.
  1. jspeccrx91
    jspeccrx91 New Member
    Kingman, AZ
    i'm working on a n/a b20/vtec to go in my crx, i just got my block back from the shop bored to 85mm. i think i'm going with the rs 12:1 pistons not sure on rods yet. what's the best header for this setup? currently have a greddy 421 header but not sure it will work with the b20 swap. i drag it mostly and drive around but it's not a daily. any tips or suggestions welcome. list of mods are:
    b20b block 85mm
    pistons (coming soon)
    rods (undecided)
    arp rod bolts
    fidanza 7.5lb flywheel
    exedy stage 1 clucth kit
    acl main/rod/thrust race bearings
    b16 head with port and polish
    dh racing dual valve spring/retainers
    (was a little iffy about them but they're working great)
    brian crower stage 2 cams
    buddy club cam gears
    accel 370cc injectors
    power products typhoon intake port matched
    hondata intake gasket
    power products 68mm throttle body port matched
    b&m fuel pressure regulator
    nology wires and coil
    vafc2
    custom chipped ecu (modified mugen program burned by my buddy)
    password jdm carbon power chamber intake
    custom 3" exhaust/no cat with an apexi n1 muffler
  2. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Hytech? :dunno: I would think something somewhere along those lines.
  3. 99sidude
    Ohio
    Yep I'd go for hytech. There are some decent replicas on ebay that can be had for far less too.
  4. efhondakid
    Akron-Canton, Ohio
  5. jspeccrx91
    Kingman, AZ
    hytech header it is, or at least a replica. any idea on what kind of whp i'm looking at and hat rods to use?
  6. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    with the mods you have listed you should make at least 200whp after dyno tuning
