Best Combination
Discussion in 'HYBRID -> EG-EK / DC' started by Johnny G, Aug 5, 2005.
  1. Johnny G
    Johnny G Junior Member
    I have a 95 Honda Civic DX and I have a 97 Honda CRV engine. I wan't to do a CR-VTEC swap, what would be the best head to use, Tranny ( 5 Speed ), ECU, Axles, etc...any help is appreciated, and I know this question has probably been asked 1000 times but i did a search and came up with zip...
  2. lsvteceg95
    lsvteceg95 Junior Member
    queens ny
    ok i have a crv aka b20 motor. here the best setup. gsr tranny,with a ls obd1 ecu, and a young gsr or b16 head. i prefer gsr cuz b16s are always beat upon. thr gsr is good for street races and highway and gas. the ls tranny gears are too long and the b16 gears are to short n it tops ot to easy and waste gas on the highway.
  3. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    Um, DO NOT get a ls obd1 ecu, you need something for the simple thing called vtec when doing a b20/vtec, but i would say obd1 gsr ecu or a chipped p28, or even a p30 ecu. Also i'd say GSR tranny.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    B16A doesn't mean it is beat up, I can find you a bunch of beat to shit GSR heads of you want. B16A transmission has enough top end for pretty much ANYWHERE in the United States, and the difference in milage between the two is maybe 2mpg.
  5. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    You definitely want to run a P72 ecu it is from a GSR you want this one because you want the secondary butterflies for your VTEC to engage. I would then get a GSR tranny and a GSR head but that's just my .02 :p
  6. brian11to1
    brian11to1 Senior Member
    you dont need the IAB's for VTEC to engage. at elast not with any other VTEC ecu...
  7. drpenguin
    drpenguin Senior Member
    Salem, Or
    yeah but if you have IAB's you want them to open right? its better then having them sit there and do nothing
