best fluid for d15b tans
Discussion in 'General Tech and Maintenance' started by spiritofjosh, Feb 3, 2009.
  1. spiritofjosh
    spiritofjosh know your role!
    ocean gate nj
    I'm getting ready to put a d15b motor and trans in my eg hatch and obviously all the oil from the trans was drained. I want to know what the best fluid is for the trans, some people have told me to get the oil directly from Honda which I assume is probably pricey and somebody else told me some gear oil. I'm just looking for opinions for this trans since it is a little old and I have no idea how it drives yet. Also how many qts do I need to get for the trans. Thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    honda is always best, but if not that castrol oil
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Honda MTF. It's about $5-6 a quart...cheaper than Pennzoil Synchromesh/GM and works better.
  4. spiritofjosh
    ocean gate nj
  5. DESPAIN
    flower mound TX
    What about royal purple?
  6. K2e2vin
    Raleigh, NC
    I've used RP in my old Accord, seems like it "wears out" and wasn't a big step up.
  7. 92egSi
    92egSi I need DOHC VTEC
    Checked with my local honda dealer it was about 8 bucks a quart..maybe the dealer near you was cheaper.
  8. K2e2vin
    Raleigh, NC
    What was the name of the dealer? I've bought fluid from both Crown and Leith, Crown was a little cheaper at $5.xx and Leith was like $6.xx
    Anyways, at $8 a quart, it's like a buck cheaper or the same as Pennzoil Synchromesh.
  9. Briansol
    honda MTF. end of discussion :)
  10. 97hatch
    97hatch ?
    Anderson IN
    honda mtf and the thing only holds 2 quarts. So its gona cost what $15 tops to change it. How cheep can people get
  11. 92egSi
    Even if honda mtf was 15 a quart I'd still buy it, better then going with something cheap and running into more problems down the road.
