R.E.Developement
Import King of Irvington
i just got a 95 integ and i want to put a h22 motor in it and boost it. is that a good setup? how much boost will i be able to handle? or should i just do a lsvtec turbo. which one is better? holla
Originally posted by greencivic@Aug 1 2003, 08:23 PM
well if you have an ls then go with the H22 but if you have a gsr then there is not point, and as long you dont run more than 14 psi with a blockgard then you should be al set trust me on this one because i took all this info from the the honda high performance book by joe pettitt he is the man this guy deals with all kinds of people he know his shit even tho some people in this forum say blockgards are crap i still belive joe pettit in the book they said as long you run less than 14 psi and a blockgard you are ok with-out blokgard dont go over 7-8 psi
even tho jackson racing says the cylinder bores start shaking at about 15 psi without new sleeves. well i hope i could help good luk H22 al the way
