best motor for turbo?
Discussion in 'Forced Induction' started by shuturmowth, Dec 25, 2002.
  1. shuturmowth
    shuturmowth Senior Member
    cali
    I'm going to get an engine swap and boost it with a small turbo(14g) and will be running like 10psi at the most...... I would like to know what the best engine for that kind of boost would be?
    looking to spend no more than $5500 :blink:
  2. kingspeedracin1
    kingspeedracin1 Junior Member
    ls turbo is the best losts of torque on power always can be added
    f-max is the best set up
  3. pissedoffsol
    5500 complete motor + turbo, ls is really the only option. anythign else, you will break the budget.
    but trust, its not a bad swap- see sig :)
  4. shuturmowth
    cali
    cool thanks guys
    will that be an easy swap into a 6th gen civic?? :blink:
  5. pissedoffsol
    if you get a 96-00 LS motor, it will drop right in with a couple easy mount changes.
    click:
    Swap -> 6th gen
  6. st00pid
    st00pid Junior Member
    GSR ultimate power production
    B16 budget high revs
    LS budget torque
    The B16 and GSR would require a decent tune to make good power reliably
    LS can be tuned by a retard and last forever
    all of the motors can make around 300whp on 93 octane with engine management and tuning. expect to make about 220-250 on FMU and BS tuning.
    jason
  7. pissedoffsol
    st00pid!! What's up man--- 'bout time you found us :)
    FYI for those who don't know- st00pid is the man who tuned that LS/T hatch in SCC that i posted a link to a week or so ago...
  8. amirxs
    amirxs Junior Member
    I got a 96 spec JDM B18C type-r engine in a civic i was thinking of boosting it.
    i know my engine is running at 10.8 compression... I will need to change
    the pistons.. maybe 9:0.1 JE pistons?
    what else should I look into? has anybody boosted a type-r?
    thanks
  9. pissedoffsol
    first start your own thread for your own question that has nothign to do with this one.
    2nd, do a search.. this was JUST talked about.
  10. Integra1990
    Integra1990 Senior Member
    omaha nebraska
    3rd, type r hav lik 11.1.1 compression, the 10.8 is gsr, if u dont kno that about ur engine good luck not blowing it wen u try to boost it
    edit- sorry ur right usdm ITR r 10.8, jdm is 11.1 my bad
