Best plugs for my motor?
Discussion in 'HYBRID -> EG-EK / DC' started by SasSi, Nov 19, 2003.
  1. SasSi
    SasSi Senior Member
    Maryland
    I have a b16a SiR-II motor from a '94-'95 EG6 Civic in my '99 Civic Si. What plugs should I be running in it? NGK spark plug numbers would be appreciated. Thanks!
  2. Smonkeyboy
    Smonkeyboy Senior Member
    Spokane, WA
    BOSCH platninum +4
    or
    DENSO plugs
    or
    ZEX plugs
    just go to Schucks/Checker/Krager or Wal-Mart and they have a little electronic thingie that will tell you exactly what model# plugs you need
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Go NGK and stay far away from Bosch.
    As stated above, just call your local parts store and ask for plugs for a Del Sol VTEC. They'll be able to tell you.
  4. SasSi
    SasSi Senior Member
    Maryland
    Yeah, but there's no "EG6" in the computer.
  5. SasSi
    SasSi Senior Member
    Maryland
    What... like a '95 Del Sol? When I tried to get plugs today, they didn't have a 1.6 litre & another time they didn't have DOHC. So, I temporarily got the plugs that are for my '99 Civic Si (1.6 litre DOHC) until I know for sure what to get.
  6. Smonkeyboy
    Spokane, WA
    you dont search for the chassis, you search for the engine
  7. MaliWho97
    MaliWho97 Senior Member
    And you sure as hell don't get bosch. Denso Iridium or IGK's.
  8. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    iv'e run bosch for years without a single problem
  9. SasSi
    SasSi Senior Member
    Maryland
    If you go to any auto parts stores, they don't let you look it up by engine type. They only let you look it up by make, year, model, and trim level. And when I tried to look up for del sol, the guy said "1.5?". I replied "No, 1.6" then he said there wasn't a listing for DOHC. So I tried to tell him the engine & he had no clue & said he couldn't look it up like that.
  10. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
  11. E_SolSi
    go with NGKs (the regular copper ones) they're about $1.25
    or get the NGK platinums (more expensive, little less power, but last longer)
    fuck all those other rip off plugs
  12. 2lua
    2lua Junior Member
    your timing belt cover should tell you what kind of spark plug you should use. mo use ngk or denso.
  13. D See 2
    D See 2 Senior Member
    Baltimore, MD
    zex plugs are very cold and are designed for turbo and nitrous use only.
    ngk's are nice.
  14. toyarmy
    toyarmy Senior Member
    nc
    i always get the densos, my parts stores dont carry the ngks.
    i love them.
    tell them a 94 delsol vtec. in 94 there was an s, si, and vtec. this is true all the way until 97.
    if theyre retarded and cant find that, i dont see why the 99 civic si wouldnt essentially be the same thing. or even a 94+ acura integra gsr should work.
    like everyone else said, bosch is bad, theyll burn up in a matter of weeks, theyre made for domestic cars.
