Best Sparkplug ? ?
Discussion in 'General Tech and Maintenance' started by slammedb18acivic, Mar 2, 2003.
  1. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    whats the best spark plug to run, im currently running denso iridium 5204's in my b18a
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Honda OEM is NGK. That's all I use.
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    There are poeple on this board that claim the Iridium is the plug to use. Personally I don't that the they show a large enough power gain with an NA engine to be worth $11 a plug. Especially when $11 almost buys 2 sets of Copper NGK plugs.
  4. slammedb18acivic
    pa
    well, i personally felt a power difference between an ngk and the iridiums. i didnt need to pay the 12 dollars a plug do to wrking at auto zone. haha. ive seen better dyno readings out of the iridium plug as well
  5. lsvtec
    Do you have any dyno sheets that compare the NGK Copper plugs and iridium plugs in the same NA engine?
  6. slammedb18acivic
    pa
    no id like to see them though.
  7. lsvtec
    As would I. If the sheets showed a significant gain I would pay $45 a set to run iridium plugs.
  8. slammedb18acivic
    pa
    i guess the answer is for us all to test whats best in our cars.
  9. endlesszeal
    endlesszeal Senior Member
    should i just use 2-3 degree colder plugs or just run iridiums when i run nitrous? i want to run nitrous but im not exactly overjoyed knowing my engine can blow up because of a stupid melted plug... i've ran 2-3 degree colder plugs before and they work fine but i want to be "safe."
  10. sportlinecrx
    sportlinecrx Banned
    FYI...NGK makes iridium plugs now too
  11. cws13
    cws13 Senior Member
    Athens,GA
    If you are worried about running the Nitrous, trim the ground strap back on the plug of your choice. This is where the heat gathers that causes detonation, which in turn melts the plug. Look for the shortest, fattest ground strap you can find. If I'm not mistaken, someone is marketing plugs made for Nitrous now, though I can't remember who.
