Best suspension for a Drag Integra?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by 12secondCRX, Dec 20, 2003.
  1. 12secondCRX
    12secondCRX Senior Member
    I'm buying a '94 Ls Integra to make in to a full Drag car and was wondering what would be the best suspension set-up for it? It's going to be an all-motor street car if that helps with the choices?
  2. theB16tegguy
    theB16tegguy Senior Member
    charlotte, NC
    Eibach sells a very nice and very expensive setup. Give them a call, hell, they can design one specifcally for your needs. Either that or get a good set off coil/strut setup. The main thing behind a drag susp. is the tuning of it. not neccessarily the brand. look at spring rate, dampining force, rebound, etc...
  3. 12secondCRX
    Is the tein set-up any good? The one where you can adjust the settings from inside your car. My buddy has it on his daily driver and loves it but will it work on a drag car.
  4. theB16tegguy
    charlotte, NC
    I like manual set-ups and personally have not seen the in car tein.
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    i think teins are more autoX related. i think eibach has a kit specially for drag racing.
  6. E_SolSi
    ground control has a drag setup as well
  7. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    :ditto:
    You want something that has Very stiff springs in back, and relativly soft in front. If this is going to be an all out drag car, this setup would be bad ass
    DTR rear suspension and brakes
  8. pissedoffsol
    1200 kg/mm rear spring rate
    400 kg/mm frnt spring rate
    and don't ever try to take afast corner again...
  9. K2e2vin
    Raleigh, NC
    the btcc civics actually run setups with super stiffys in the back(rear are like twice the spring rate than in the front).
  10. 12secondCRX
    Thanks for the reply's!!
  11. 12secondCRX
    What rates does that equal out to? I was thinking of 450 front and 900 rear.
  12. K2e2vin
    Raleigh, NC
    i just noticed...do you mean 400lb/in,1200lb/in? because 400 and 1200 kg/mm is rock hard, literally.
  13. 12secondCRX
    Well I talked to my buudy at the shop and he said to go with Ground Control's, so what do you guys think?
