best swap
Discussion in 'Accord' started by darealmos, May 20, 2010.
  1. darealmos
    darealmos New Member
    :ph34r: I have 94 accord 4 door best swap 4 dis car?
  2. BrutalB83
    Rochester Hills, MI
    Probably an H22, but your question is very vague. What's your budget? Power goals?
  3. phunky.buddha
    Dallas / Fort Worth, TX
  4. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
  5. 94H_Ex
    94H_Ex Under employed
    Florida
    F'ck it, 200sx Fwd Sr20det swap.
    If you search hard enough I believe you can find a fwd transmission for a Chevy 454 from an old Rv.
  6. darealmos
    well budget 1500 and power wise over 200 horses
  7. 34diesel34
    34diesel34 Import Tuner
    USA
    Fuck it. go RB26dett or Hemi:fosho3:
  8. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    he already has a hemi
  9. BrutalB83
    Rochester Hills, MI
    Not going to happen then. If you were SUPER thrifty you could maybe scrounge together an H22 swap for $1,500 total, but even the H22 tops out at 195-200 horses and 160 ft/lbs torque...
  10. phunky.buddha
    Junkyard turbo the F block, assuming it's in good condition.
  11. BrutalB83
    Rochester Hills, MI
    :werd:
    This is probably your best option to make 200+ horses on that budget...
  12. powerdriverh22
    spfld, mo
    x2
  13. darealmos
    Word..... Can i use f22 trani and do i need h22 ecu and wire harness what about turbo charging it
  14. BrutalB83
    Rochester Hills, MI
    I'm not sure exactly what you're asking here. If you're talking about for the H22 swap, then yes, you can use the F22 tranny to save a few bucks. The gear ratios aren't as aggressive as the H22 transmission's though. And you don't necessarily need the entire wire harness, but you will need to at least make a few wiring changes (to accomodate VTEC) and yes, you will need an H22 ECU or another ECU that's been reprogrammed to run an H22.
    As for the turbo setup, check out our reference section articles and the sticky articles in the "Forced Induction" forum to get an idea of what you'd be getting into...
  15. darealmos
    kool brutalB83 ... any books on honda swaps u recommended
  16. darealmos
    found a h22 4 $850 has about 10,000 miles on it is this a good buy?
  17. BrutalB83
    Rochester Hills, MI
    You can try "Honda Engine Swaps" by Aaron Bonk for some good info. You should be able to find a copy pretty much anywhere (Barnes & Noble, Borders, Amazon, etc.)...
    If it's in good shape, then yeah, that sounds pretty decent...
  18. darealmos
    friends tell me to buy a p28 ecu is this right?
  19. eg6sir
    for tuning purposes, yes... to just slap in there to run the h22, no
