Quoted post[/post]]
In the Amsoil brochure, I believe Mobil was the second best...
of course they arent going to say their brand isnt the best, but it does show Mobil being better than the other brands...Quoted post[/post]]
WELL TO JUST KEEP IT REAL............NO BRAND IS GOING TO DO A TEST AND PUT THE RESULTS OUT THAT DO NOT SAY THAT THEY ARE THE BEST......!!!!!!!!!!! I personaly don't know which of the two is the best but i do know that............
Quoted post[/post]]
You should be running 5-30 or 10-30
I'd recommend 5-30, much thinner and runs smoother
I just bought a box of 12 quarts of amsoil at a local dealer for 65 bucks, great stuff
just switched from 10-30 to 5-30 on my b16 and it's really much smoother
Quoted post[/post]]
mobile 1, then castrol syntec.
You can't go wrong with either one.
P.S. If the engineers at honda built the motor, and then recomended 5w30, don't you think that is what you should be using?
They designed it specifically for 5w30. Not 10w30 or 20w60. The tolerances are all spec'd to 5w30 oil. Use it.
