seanjuan
I have heard stories of civic rear subframes tearing/shearing under stress from having a big sway bar installed and was wondering what the best way to prevent this would be.
Comptech makes a kit for the EK's that has a swaybar and a billet plate that ties the subframe and provides mount points for the swaybar bushings.... would this fit an EG?
there is a similar kit by Suspension Techniques that has an adjustable tie bar instead of a solid piece... they make a kit of the EG, would the adjustable tie bar be better or worse as far as subframe tears are concerned?
there is another company that makes a kit for strengthening the subframe as well but it doesn't seem like that would do much (Beak's Subframe reinforcement kit)
also, are there any sway bar kits that can be used on a car that didn't come with a rear swaybar? or would I have to get new LCA's that have the mounting holes allready in them?
thanks
thanks
