Best Year Civic and Engine Combination ???
Discussion in 'Civic and CRX - EF' started by SunShine00, May 28, 2007.
  1. SunShine00
    SunShine00 Eager Student
    im about to buy a civic and drop an engine in it , i was thinking about a 95 hatch and i think the lightest model is the vx or cx , and i wanted to drop a H22 engine ?
    Correct me if im wronge :confused:, and any opinion's much appreciated :D
    1 person likes this.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    The lightest 92-95s are the CX and VX. They're wonderful shells to throw H22s into. Check out Bisimoto's H to D conversion kits too.
  3. eg6sir
    92-93 CXs anv VXs are the same at 2094 lbs .. the 94-95 the CXs got a little fatter and gained like 12 lbs while the VXs stayed the same at 2094
  4. SunShine00
    what about the 96-2000 civic hatch's are they much heavier ?
  5. m90polk
    m90polk Member
    ri
    h22?
    not for anything but I wouldn't throw an h22 in a hatch because it really messes with the weight transfer when you brake and corner. so from what ive heard if you did it you wouldn't get very good handling out of a car that small regardless of which model hatch you get. but i mean the choice is ultimately up to you personally i would go B18C<-:cool:
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    The H22's don't weigh that much more than a B-series swap(IIRC, with the H2B kits, they weigh about the same...weight difference being in the transmission).
    The +96s are indeed heavier but not sure how much. I've seen 2300-2600lbs thrown a lot for that chassis.
  7. SunShine00
    yeah the h22 engine and trany , is only like 40 lbs heavy'r , than the b18 c ,
    I heard that the H22 have problems with the trany's , has anyone else heard that , because im seriously about to buy that engine
  8. K2e2vin
    Raleigh, NC
    I've never seen a busted H22 transmission, but they're suppose to be more beefier than the B-series transmission. If one ever fails on you, there's plenty of F22 transmissions that can be had for cheap.
  9. SunShine00
    oh yeah , thanks , do you know anything about putting a turbo on a H22
  10. m90polk
    m90polk Member
    ri
    h22
    another reason not to get an H22 is if your getting one from a 97-2001 Honda Prelude then the cylinder walls are actually made of carbon fiber. You have probably never heard this but they are and under immense pressure of repeatedly racing the car or high performance bolt ons (turbo)the walls have a tendency to warp, you might not believe me but my friend is a Honda technician and they have seen this quite a bit.
  11. K2e2vin
    Raleigh, NC
    They are not CF; they're FRM(fiber reinforced metal). The S2000 uses FRM also. Draw backs is different honing/boring method(if that counts) and you can't use forged pistons.
  12. K2e2vin
    Raleigh, NC
    I don't know, I just read that the service limit is like .75mm overbore or something like that; which implies it can be bored or just honed to death. It should be in the Helms Prelude manual.
  13. eg6sir
    you worried about head clearance?? i'm 6'2" and i'm riding Prelude seats on EG rails, so i sit higher than your normal EG.. i have no problems w/ head clearance, even in the back seat
    looked around and couldnt find shit for info on the 88-91 Civic..
    anyways..
    95 Civic
    - Internal dimensions: front headroom (mm): 980, rear headroom (mm): 930, front hip room (mm): 1,265, rear hip room (mm): 1,133, front leg room (mm): 1,080, rear leg room (mm): 775, front shoulder room (mm): 1,356, rear shoulder room (mm): 1,323 and interior volume (liters): 2,175
  14. phunky.buddha
    Riiiiiiiiiiiight. They handle boost just fine. The sleeves are still made of metal. 350-400whp has been done reliably on the stock sleeve, and in daily driven cars too. The S2000 sleeve (also FRM) handles 500whp+ without any issues at all.
    You can run a few sets of pistons in the stock sleeves- not that many, but they are available.
  15. eg6sir
    hahaha.. cylinder walls made of CF... hahhah.. thats a good one
  16. K2e2vin
    Raleigh, NC
    I know Mahle makes some. :)
  17. phunky.buddha
  18. 89crxzc
    89crxzc I provide inspiration!
    ohio
    97 four door with frankenstein or k series, trust me its ubber fast
  19. EvoTec1
    EvoTec1 Member
    Tacoma, WA
    boosted h22's blow up.
    I mean not ALL of them....but you WILL eventually get greedy and go for big numbers...
  20. SunShine00
    HOw much more do the 96 - 2000, civic hatch models weigh ?
