Better Bottom End D16a6 or D16y8?
Discussion in 'Civic and CRX - EF' started by Reboticon, Jan 4, 2009.
  1. Reboticon
    Reboticon New Member
    Knoxville
    title says it all. I have bottom ends from a d16a6 and a d16y8. Using Y8 head. Which block should i use? I hear theY8 has oiling problems?
  2. D16SiHatch
    D16SiHatch New Member
    they do have oiling issues which occasionally leads to a spun rod bearing. i would use the a6 bottom end.
  3. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    :ditto: The Y8 does have oiling problems. If you were to use that the bearings would have to get umm, bored a little more? Ugh! I have an article on this somewhere, as well as the oil pump. They are infamous for spinning bearings. Go with the A6. You'll be happy with it. :thumbsup:
  4. 89' Project Civic
    89' Project Civic d16a6/d16y8 "mini-me"
    St. Catharines, Ontario, Canada
    I hear the comp. ratio is better mating a VTEC head to a NON-VTEC block as well!. gl
  5. Luis998
    Orlando, Florida
    :huh: Which head/block combination are you refering to?
    To the OP, check out this link. A good friend sent it to me yesterday, as I had lost it in the mix. This will help explain the things that can be done within the Y8 block in order to prevent oiling problems. Enjoy. :D
    The Old One - Energy Dynamics : Articles
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    dude stop spamming and bumping old threads,make your own,
  7. Reboticon
    Knoxville
    Erm right back on topic.. Suggestions on what Head Gasket to use? Going with the D16a6 block and Y8 head that is. Thanks.
  8. haao13
    haao13 New Member
    PA
    you use the headgasket that matches the head
  9. Luis998
    Orlando, Florida
    :ditto: Y8 head for the win. I would also stick to OEM as well.
  10. 89' Project Civic
    The Y8 HG offers higher compression if it's 2-layer, OEM is the best bet like Luis998 said. Also Luis998, I'm doing the d16a6 (block), d16y8 VTEC "Mini-Me" Head swap. Thanks for your response.
  11. 89' Project Civic
    that's a really good write-up, thanks!:)
  12. Reboticon
    Knoxville
    Again, Many thanks.
  13. Luis998
    Orlando, Florida
    Let us know how it goes and best of luck to you my friend. :thumbsup:
  14. Dseries
    Dseries its not bought i built it
    so im assuming the y7 block is just as inferior as the y8 than? cause i have one of those in the garage that i kinda had plans for.....
  15. 89' Project Civic
    Do you think in your situation that just a performance oil pump would work?. Might sound dumb and all but something to look into. I think I heard that the d16a6 block with a d16y8 head increases hp due to compression, then your problem would be solved!.
