Big or small
kermit5327
Member
ok so ive got everything ready in my car and im wanting to know should i go with a big turbo and low boost (5 to 8 pounds) or a small turbo and higher boost (12 to 15 pounds)
now mind you this is going on a d15 non vtec
For a daily driver I would run a smaller size turbo with as much boost as you can afford to build the motor with. Keep in mind you're going to need some good engine management/tuning and build the bottom end if you want to run anything over approx 8 PSI.
ok i plan on getting a jdm d15 and doing some work to it but im not gonna go all out on it
