Big Problem!!
Discussion in 'Other Vehicle Discussions' started by B16RacerN2NR, Mar 16, 2004.
  1. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    ok first off, the car is a 94 Galant. it has the 2.4 DOHC motor. my problem started when one day my rpm's dropped dramactiacally while i was driving. if i was going 70mph at 3k rpm, the idle would go down to like 1300rpm and i would get a check engine light. so if i keep driving, it'll go away and the car will run normal again anywhere from 2 minutes to as long as an hour. i checked to see if i was getting spark and cylinders 2 and 3 weren't getting spark from the coil pack. so i changed that coil pack out and now the problem only occurs half the time as much as it did. so my guess is i only fixed half the problem. i have yet to look at my plugs and the wires are in great condition but they are ok. would a fouled plug cause this? any help or any ideas would be great. if there's any info that you need to help me, just ask, thanks.
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    hmm...not sure.
    I would do all the routine maintenance that needs to be done and that was possibly ignored.
    on a side note......I feel the problem is the diamond star itself, very unreliable
  3. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    :withstupid:
    Mitsu = teh ghey
    :yuck:
  4. whiteLS
    whiteLS Senior Member
    Sarasota, Fl
    if its ne thing like gm coilpacks it might have taken the wires w/ it when it went bad,
    check the plugs too
  5. B16RacerN2NR
    Moving back West...
    thanks for the replies, yeah i know DSM scks but i only use the car to commute 120 miles a day to work. it's been pretty reliable thus far. i'll check the wires and the plugs as soon as i get off work at 4:30 in the morning. anyone else have a thought?
  6. TurboMirage
    i agree. the galant is considered a DSM.
    ocasionally, the 1.8L mirages have this problem. most change the plug wires AND the coil packs at the same time.
    you may want to sign up on a galant board.
  7. B16RacerN2NR
    Moving back West...
    yeah when i checked for spark only one coil pack was out. i would of changed both but each one is like $80! i got the plugs already, i have yet to change the wires. also, i noticed that if i use cheap gas (arco) the problems occurs like 5 times more often. If i use chevron, the car will drive for a longer period of time. now, this has only happened once so maybe it's just a coincidence but do you guys think some fuel plays a role as well? or does the problem sound more like a spark issue?
  8. MugenCRX
    MugenCRX Senior Member
    Thornton CO
    Good Fuel + Good Spark = Good combustion
    Good Fuel + Bad Spark = Not so good combustion
    Bad Fuel + Bad Spark = Little to no combustion
    Any Fuel + No Spark = Absolutley no combustion
    ^Just my theory.
  9. B16RacerN2NR
    Moving back West...
    yeah...#3 kicked my ass for a week
  10. TurboMirage
    you could change your fuel filters...
    but its an electrical problem.
  11. B16RacerN2NR
    Moving back West...
    yeah, this weekend i'm gonna put the new plugs and wires on andi'm gonna dump some fuel system cleaner in the tank...wish me luck everyone :( :blink:
